WiFi setup
I faced similar problem, Try this solution if you have same kind of card.
WIFI driver nl80211 / rtl8188eu / 0bda:f179 Realtek Semiconductor card - Networking - Hive OS Forum
Hi, I have an identical one. Did you use any specific command? Exactly how did you proceed, can you tell me step by step?
I have this problem too…
hello! does the “148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter” driver still work? I have a Trendnet 806-UBH dongle that uses this same chipset but I can’t seem to get it to work on Hive.
I am having this issue where I need to enter my wifi credentials every time after a reboot then it works. I looked for the file wlan0 in that directory but it doesn’t exist. Do I need to create it? Also what is the actual text and what is just a description of what is needed?
you need it. Also check you have /etc/wpa_supplicant/wpa_supplicant.conf
wlan0 should look somewhat like this
auto wlan0
iface wlan0 inet dhcp
wpa-ssid your_wifi_ssid
wpa-psk your_wifi_hash
I found one of the reasons causing the wifi to not work properly
There is a Variable in wifi access points called "Group Key Update Interval" If it is too low, it won't connect properly. I set it from 20 --> 20000 and it started to work normally.
You can change it in your router settings
