quote from general usage for TRM "Ethash options:
–eth_config=CONFIG Manual ethash configuration for the miner. CONFIG must be in the form [M][L].
The [M] value selects the mode which can be ‘A’,‘B’, or ‘C’.
The ‘B’ mode uses additional memory and will only work on 8+GB cards.
The ‘C’ mode uses additional memory and will only work on 16+GB cards, such as the VII, with
a correctly configured system. See the ETHASH_TUNING_GUIDE.txt for more details.
The [L] value selects the intensity and it’s range will depend on the GPU
architecture.
Both values are optional, but if [L] is specified, [M] must also be specified.
Example configs: --eth_config=A
–eth_config=B750
CONFIG can also be a comma separated list of config values where each is
applied to each GPU. For example: --eth_config=A,B750,,A288
Any gpu that does not have a specific config in the list will use the first
config in the list."
So it should be quite straight forward to set each gpu to different mode and intensity. I havent tried yet, but these extra configs would be handy to set for few cards that are running hot to lover intensity or different mode alltogether.
