Vega 56 and Vega 64 guide
I have one card with same description, i cant get it online in hive, the card is PowerColor Red devil 56 but in hive it shows vega pro v320. i belive my card is defected is not possible to repair or recover.
no, i was trying to find it, was the repply on this thread. thanks
Running Sapphire 56 solo directly on MB at 16x. best stable i can get is 41.5 on ETH.
core 1050 / vdd 812 / mem 900
Any thoughts on getting past the 50 mark? Also how is this done via a riser? I cannot seem past 9MH via riser.
Also what version of Hiveos do you use? 6-201 is the newest I can use, newer fails to load any miner.
You have to rise memory, are you sure your straps are applied properly?
Hi, what could be the problem? after that, the farm is constantly rebooted
Finally over 50mh WITH a riser. But shortly after its tuned I get dead GPU.
amdmemtweak --CL 20 --RC 36 --RP 12 --WR 13 --CWL 8 --FAW 12 --RAS 22 --REF 65000 --RFC 249 --RTP 5 --RRDL 5 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
Still need to tweak it but am happy. You think I can add some 4gb 570s on risers? Last I ran them they had to be full 8-16x ported to be any use.
Hi guys! i just put my vega 64 in the rig and i have a problem with the straps.
i flashed the card with 56 bios and did the overclocks and when i put the straps the rig crashes
OK, after another day of tweaking I am stable with just at 50mh.
amdmemtweak --CL 18 --RC 34 --RP 13 --WR 11 --CWL 7 --FAW 12 --RAS 23 --REF 17000 --RFC 164 --RTP 6 --RRDL 4 --RRDS 3 --WTRL 4 --WTRS 4 --RCDRD 11 --RCDWR 11
next step would be a full cleaning of the card. Not sure a Sapphire card with Hynix mem can get better.
Max is 52-53 as I know with mem 960-965. But your straps RCDRD and RC are very tight, if card crashes with higher mem use RCDRD 12 and RC 35-39
Core clock 1030
Start with “easy” straps and lower RCDRD and RC one by one for testing. Finding the best settings is a-few-day process for vegas that’s why they are so fun :sweat_smile:
Seems to be straps problem.
U can send me some easy straps to start
Try these
amdmemtweak --CL 20 --RC 39 --RP 11 --WR 14 --CWL 8 --FAW 12 --RAS 20 --REF 65535 --RFC 248 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 18 --RCDWR 12
Im gonna try it later today but for oc i use
1000 on clocks
850 vdd
960 on memory clock
Is it good?
Mem clock 960 doesn’t work on every Hynix card. If it keeps crashing start with 935mhz
best i can get is 925 with very liberal straps. Think i am content tho at 50.
idk but i can t run any straps like when i apply them it crashing my card.
the max out setting with a strap is 870 on memory till is crash
when my vega 64 goes over 45 mh it s crashing any help?
