mv trex trex.old
At this line i got
root@B150:/hive/miners/t-rex/0.23.2# mv trex trex.old
mv: cannot stat ‘trex’: No such file or directory
mv trex trex.old
At this line i got
Can you share screenshot pls I am noob about this things
. I couldnt make it
I think the update services are closed for maintenance?
what is that user name aslkdjaslkdjasdık.rig/test@gmail thing where can I find mine
Ok it must be that command I did wrong. I am no Linux expert. I can copy command lol thank for your help!
I did configure the second algo like your exemple.
But in the miner screen I see 23.2 so it must be that…
Checked on my side with t-rex 0.24.0
if i configured with “lhr-algo”: “autolykos2” there is an error on t-rex side
20211008 13:22:16 ERROR: Can’t start T-Rex, can’t parse json:
We have to wait until hiveos team handle properly settings via json file.
Best Regards
Can you share your OC?
Can you do a video or full guide for noobs like me ?
yes because there’s a typo… There is no trex… it’s t-rex
use the following command… Actually inside the miner tuning page it now shows 24.0 for me so i chose that instead
Will be testing soon…
mv t-rex t-rex.old
My friend what is your OC value?
Please share.
Good catch on the typo. I updated the top level post to fix the typo
30% eth +70% ergo is worse than 100% rvn
so we’ll be mining ERGO for your wallet… SMART!!!
Well I didn’t catch it until I used it and I tried finding the file that the shell couldn’t find
I can’t for the love of god find a setting that won’t trigger an lhr lock… Well then ergo profitability is down so I guess it doesn’t really make any sense right now
