July 7, 2021
New features:
- Added sorting by VBIOS on the Cards tab
- Added new filter memory + VBIOS on the Cards tab
- Improved DHCP icon indication
- Integration “Ykeda Autofan”
July 7, 2021
New features:
July 15, 2021
New features:
July 27, 2021
New features:
September 1, 2021
New features:
October 7, 2021
We’ve added a new functionality with this web interface update:
New options added to Nvidia Overclocking. Force P0 state and Idle state. Both options require Hive Linux client v0.6-205@210715 and higher. Please note that restarting the miner is required for the changes to take effect.
Using this option forcibly turns on the performance mode P0.
P0 is a fixed maximum power mode, note that it also raises the memory base clock by 400MHz, so keep this in mind when setting memory overclocking.
P2 is an adaptive power mode that can decrease and increase frequencies, which can lead to failures at the time of a sharp decrease/increase in load, for example, switching to a failover pool or regenerating the DAG file.
For mining versions of GPUs, setting the P0 mode is not needed, so this mode for them, in most cases is the default mode. GPUs designed for gaming work in P2 mode by default.
Enabling the “Reduce idle power consumption” option will significantly reduce power consumption during idle time (when mining is stopped).
Nvidias OC panel’s new look
Also added tooltips for some parameters and corrected a few terms.
New miner for Nvidia and AMD GPUs added.
Currently miner supports ethash and etchash algorithms. Miner devfee is 0.5%.
BzMiner in action
Now you can add Farms and Workers to Favorites.
Favorites | Farms
Favorites | Workers
Adding a new worker (rig, ASIC, ASIC-Hub) has been significantly redesigned.
Now with a friendlier look for new users and more appealing to existing users.
“Adding New Worker”'s New Look.
“Adding ASIC”'s New Look.
“Installing ASIC Hub”'s New Look.
“Adding rig”'s New Look.
Added indication of farm ownership on farms
Workers drop-down list’s New Look.
October 22, 2021
We want you to be comfortable using Hive OS. Therefore, we cannot be stopped in the search for the most effective solutions!
In this update, we have brought the following new features and improvements to life:
Dual mode for T-Rex miner
Integration of the new miner TeamBlackMiner
Made minor improvements when creating a new rig / ASIC
Improved visual experience when working with lists of favorite farms / rigs
Further on, in more detail about the main changes.
Starting from the miner version v0.24.0, the dual mining feature has been added to the T-Rex miner.
What does this mean and how does it work? As you know, Nvidia began to block mining in ordinary game cards, which is reflected in a two-fold decrease in the efficiency of mining in relation to unblocked solutions. Miner developers are constantly improving their blocking bypass algorithms, but a significant part of the resources are still unavailable. In this regard, the developers of the T-Rex miner have created a special dual mining mode, which allows you to use the resources of the video card by 100% while mining two coins at the same time.
The following modes are available:
More info can be found here
Also, starting from version 0.24.2, it became possible to mine ZIL coin by switching from ETH mining during Zilliqa PoW window.
To make it easier for users to configure these modes, we updated the T-Rex miner setup form and added the output of the hash rate of the second algorithm to the dashboard.
Updated form for T-Rex miner settings
Displaying the hash rate of the dual mode in the dashboard
TeamBlackMiner allows you to mine Ethereum, Ethereum Classic, Zilliqa with a developer commission of 0.5-1% on Nvidia and AMD cards
Sources:
TeamBlackMiner configuration form
TeamBlackMiner in action
November 11, 2021
The new watchdog option “miner shares WD” addition. Avoid downtime when a miner reports hashrate but does not send shares to the pool for unknown reasons. The watchdog will restart the miner if no shares are found for a specified amount of time.
The function of pasting the miner config in the tooltips has been improved.
December 20, 2021.
In this web interface update we have added new features:
Added DanilaMiner integration
Added dual-mode setup and stats for lolMiner
Here’s a little more detail;
This miner has been successfully integrated by the developers as a custom miner. The Hiveon team decided to support the project by adding built-in integration of this miner, which should make it even easier to set up, update and mine the TON coin.
Miner in action
Setting up the pools.
Flight sheet
Miner settings window
The miner currently has several operational options that fall under the so-called dual-mode:
This will also allow you to add new dual modes, which will appear in future versions of the miner
lolMiner settings window (split mode ETH+ETC)
