2100 max for most GPU’s
When I said max mean no Invalid now 5 days
you can see some 2100 and some 2090
each invalid reduce 10 so if 2100 invalid reduce to 2090 etc,
Any update fro the problems ? got same problem , change riser ,cable, default config still 1 gpu got invalid share on hiveos , on the pool no problem , miner TRM 0.90
need help , or should ignore the invalid on hive os
