I try it tommorow mine,guys how much power yours gpu need?
Mine need 2*8pin+6pin and have huge cooling system
My card is mining at 46,7 Mhs. Using T-rex for ETH.
Fan 70%
Mem -200
Clock 3400
Power 180W
No rejected shares and temp around 50.
See you!
Printscreen pls to see that.
Now it’s abit better… Changing miner to nbminer 39.2 we are getting 52 MHS in ETH mining. See below:
Hello, i could get 54-55 in ETH in my 3070 TI Cards using nbminer 39.2, Just switched 1 to RVN because i want to avoid Gas Fee on Ethermine, but you can see a clear diffence on consumption and heat.
is it the asus TUF? do you need to reapply the new thermal
paste? I applied new thermal paste for mine yesterday and temperature of core and hotspot increased. The temp for vram decreased but it still reach 105 after maximum overclocking
I was struggling to stabilize my 3070TI Zotacs until I found this configuration. I’m using Phoenix pool. 15 days without interruption, only those small flickers that we can see in the image. No overheating. Pretty much stable right now. However, I’m trying to find out a new configuration to rise every card above 50MH. I think is possible.
My friends using latest nbminer and with similar clocks have around 57mh
Exactly what I’m looking for. Can you find me a print screen? I’ll really appreciate it.
Same oc like yours but using latest nbminer,try it
here is what i use for ETH stay solid 57~58 power can move up and down a bit but seems to stay around 200 but will spike to 280 sometimes and hit the higher 58 mhs area then back down to 57.5 or so @ 200 watts
fan 65。 1060。2600。190-200。 56-57mh
hi if u find oc told me
Guys update Nvidia driver 495.46.
Core clock locked 1050
Memory 2400
No power limit for ETH.
Stable 180w at 59-60MH
Using TREX miner with LHR 74.5.
PNY 3070ti
Edit: It was running like that for 10 days stable. Just restarted for clean maintenance from dust.
