It is very difficult to get the highest performance
That didnāt work but Iād still like to see at least 110 across
You should try a lot
put ā¦core -170 mem 2150 pwr 1900
And send a picture
I would look at the PSU and riser. Whatās your PSU model and rating?
You better not be powering the riser through a SATA cable. Especially with an RTX 3090 which the PCIe slot on the riser would almost certainly hit the 54W rated SATA connectors. Power your risers directly from the 8pin VGA ports from your ATX PSU or from a server PSU with 12V 6pin breakout boards
If youāre using a good quality PSU and risers are powered properly (i.e. not SATA), then itās likely a thermal throttle on the memory. Unfortunately NVIDIA has not released the sensor API for monitoring memory temperature for linux-based OS, so you wonāt be able to see this on HiveOS. So get a thermal probe, infrared thermometer, or FLIR gun and point them at the backplate. If itās above 115C, then itās likely a thermal throttle on the memory.
EDIT: How long have you been mining on these 3090s? Probably youāve been mining for some time and the GDDR6X memories finally gave in to thermals?
hi guys i got +64.5 mh from my evga 3070 but i dint know if my card is in danger or not
if its in danger tell me to downgrade my oc
Abbas
3070 is not 3090
Sawyer
at least EC360Ā® BRONZE 8W/MK THERMAL PAD, better EC360Ā® SILVER 12W/MK THERMAL PAD
Iāve changed the way the wires are connect. no sata wires just pcieās. and the load on the cords should be way less although no change has occured.
hi
core -300
mem 1800
pl 300
That also didnt work. We have the same exact gpu. Will you send me pictures of your rig. What are your specs
Hello.
The Problem are the thermal Pads.
I also have 4x RXT 3080 and 1 x RTX 3090 from Gigabyte, on all cards when they run a while, the hashrate falls down,ā¦
you have to change this pads, and than you reach the maximal Hashrate. Search under Google, there you can find some videos how to change it.
Good Luck
Is this a common thing. Or do i need to find better quality padding? How often do you have to change?
I also noticed the power limit is never reached also
Yes, that is a common thing. I have a fried with also the same problem.
You have to change the pads when you see the Hashrate is falling down. I recommend every 3-6 months.
I bought this one, and it works perfect.
Ok thank you. How much ram do you have running. If i run one or two cards I can keep it at 104 to 108 mh. But when i go to 4 it all drops to 98ish. What motherboard do you have also
3080
1900 ā -200 ā 230Watt ā 98MH/s
3090
2200 ā -200 ā 300Watt ā 118MH/s
I get 124.9 MH per 3090with the following:
Core - 1400
Mem - 2700
Power - 315
When I drop my core below 1300 or above 1500 I get a drop in MH. I have 3 RTX 3090s and they are all set the same. I started out using -200 for core but I got the same numbers as you.
Hives does not show the memory temperature. You have a throttling memory under the backplate, the temperature exceeds 110C. Or there is a problem with thermal pads at all for many 3090 cards from different vendors. You can put an additional radiator on the backplate through a thermal pad, there are many videos about this on youtube (adding radiator 3090).
