RTX 3060 ti - NBminer 39.7 not stable on HIVEOS
With those settings (1410 core, 2150 memory, no PL) each of my cards range from 125-140 watts. They seem to stay in the 130~ range for the most part, but occasionally spike higher. They have never past 140 watts though, and the spikes only last like 5 seconds before coming back down towards 130w. So far, my OC settings for these 3060 ti’s w/ Hynix memory seem to be the perfect balance to keep a stable 44-45 mh per card after this 39.7 NBminer update
Yep… Very good oc indeed. Have you tried to get a little bit more?
Mine sit on 46.6 on NBMINER
I’ve tried, going any higher/lower on the memory usually ends up dropping the hashrate a little. Same with moving the core
Sounds like you have Samsung memory. We’re talking about ones with Hynix memory
Yeah, same here!!
Collapsed
ok … I have figured the 3060TI actually works pretty well with the VNIDIA 495 driver and the 39.7 NBMINER software with an older Hiveos version.
0.6-208@210818
seems to hold on and become pretty stable.
:heart_eyes:
is stable so far?
Yes it is. still getting 47.37 mh on Nbminer 39.7 using Nvidia driver 470.82.00
I read that for hynix memory cards we use negative memory clocks… have u tried that?
Can you give the setting OC, driver version and version hiveos, because i have 3 gpu 3060ti lhr with hynix memory, with nbminer 39.6 just stable on 40-41 mh/s
can you share your oc settings please
Driver 470.63.01
Stable for 3+ days. Make sure your NBminer is updated.
Sure, here it is. 1600 core, 3000 mem, 135 PL. I just copied this somewhere. Let me know if you can improve on this.
ok thank you
I was running smooth on 4 3060ti zotac hynix with core 1200/mem 1810 / pl 165 @42Mhs. After I added 2 more cards everything is on toss. I can’t keep rig with 1200 core / 1810 mem. It runs into high load average with irq/132 consuming 100% cpu. Tried with nbminer/trex but same LA issue. Now again sarting from base OC. Till now reached to 1100 core and 1730 mem. Let me increse in steps and see where it starts causing LA issue again. Tried upgrading to latest Hiveos with 470.82 nvidia driver.
My zotac 3060tis running smooth for a week now at 1350 core / 1800 mem / pl 160 on Trex 470.63
