Even during testing, we paid attention to the temperature. When changing the settings, if the temperature was below 50, or above 57, the hash rate would certainly drop.
Hey folks, I installed my new gigabyte 3060ti LHR yesterday and it’s stable on T-Rex miner at 135mh/s @ 120w. Not going to complain too bad, getting decent hash per watt for LHR on ergo.
able to acheive 35+ on 3060 (2504), however my other cards 1660s and 1660Ti were not able to pick that MH speed which was stable on NBminer… any OC setting for 1660 series for MINiZ
You could mine on t-rex and miniZ, miniZ gives me pretty stable 100-101watts no fluctuations for 33.60mh/s on a Rog Strix Samsung memory 3060 V2 LHR and my other cards I run on t-rex since t-rex seems to be the better one for power efficency (yes I know I can run 1080 ti higher, I got a second one with 3 fans as well, I hate them and are selling them, they are power hungry troublsome fellas, and I dont justify 42-45mhs/s at 205-215watts).
Make sure you put the device markers (change your numbers according to your gpu numbers, check mine on the right hand side for referense) both in t-rex and as cd-# in miniZ.
Check pictures.
PM if anything. Hope I could help at least a bit. Best regards, D.
thanks @Danilak for the response, my views on mining on different miners
till now NBminer 39.2 is the most stable for me giving 34-35.9 or even 36 on my LHRv2 3060 without any LHR Lock detected trap.
for my other cards in rig 1660ti and 1660 super (asus with hynix memory) does not go up beyond 31.7 whatever I have tried — now I am planning to flash PALIT Rom in my 1660S to achieve 35
I also used Trex and Gminer, however power fluctuation were very high and it was not kind of stable and i moved back to NBminer
with MiniZ, hashrate for 3060 was kind of stable with 45 but with little more power consumption and my other cards were not able to get the speed properly, so i switched from MiniZ also
try lolminer it fixed the problems for me.How much did u get on miniz
Hello marinetough,
thanks for the info, I only get 24.75 Mh.
It’s weird that it doesn’t work for me.
on Miniz it was fluctuating a lot actually, so it was between 33 to 36 with lots of “Lock Detected Error” and they actually makes your mining inconsistent and your profit gradually becomes lowers
i am using 460.91 version and almost getting the same hash rate on NBMiner, upgrading or downgrading the Nividia driver on HIVeOS is painful activity and may create some downtime
wich miner?
NBMiner 39.2
Hi, what are your settings for the Gigabyte card?
On which coin?
At ERG and ETH…
For ETH i use 1450 Core + 2650 MEM + 110PL
For Ergo it various up to each card from -500 to -350 core + 2650 MEM + 100 - 105 PL.
I just manage to stably pull out around 95% capacity on 3060 12GB LHR V2 on TREX 0.24 Dual mining.
15MH ETH = 30% of 50MH full capacity.
15MH RVN = 65% of 23MH full capacity.
Here is my OC & driver running this rig, Stable for 17 HRs now.
