Thanks for this. Helped me realize I needed to update drivers. Btw, your temps are insanely high. I can’t imagine the mem temps. How are they not thermal throttling?
im using driver 460.84
Picked up a Zotac 3060 White trying to find the sweet spot on the card for ergo.
so far it takes 10w less to get anywhere near the Gig cards i have which put out 116-119mh each.
ill report back with my findings
EDIT:
After 30 minutes at it… Here is the hashrate
Card: ZOTAC GAMING GEFORCE RTX 3060 AMP White Ed
OS: HIVE
HASHRATE: 116.7
SETTINGS: core -548 / mem 2600 / PL 107
I have a spreadsheet going for all my findings as i go.
If 3060 v2 try this
Core: -242
Memory: 2600
Pl: 102
This is the version 2 LHR of the card mining ERGO:
I have also found just setting the power limit to 100 and leaving the other settings at stock (zero) works good as well.
You can get pretty efficient mining in ERGO, using the nvidia-smi commands via the RUN COMMAND:
nvidia-smi -i 1 -lgc 1220
I made a video where I do it in Windows, but show work fine in HiveOS: https://youtu.be/yDbIE3XNs5Q
Ты лучший!
I was using -390 but on another post, a guy suggested -330 and I’m now running at 116 MH.
which 2 coins are you mining? ERGO and ETH? Your values are beautiful. What program did you set these two miners with?
If you want lower power consumption which means lower temps try these settings:
5x LHR version 1
1x LHR version 2
power limit used?
I had them set at default 0.
are this work with rtx 3060 LHR v1 ?
What are you mining bro?
Yes all my 3060 are LHR v1
I’m mining Ergo
Dual mining?
Yes dual mining (ERGO/ZIL)
In where do you type this?
