i try your bios, but the fan is always at 100%
it’s possible to dehe speed? hive os don’t apply my setting
Hi, and how much did you manage to get MH? what miner do you use? what settings?
Hi. I’m not solved my problem yet. I’m flashed stock bios from backup, and steel waiting, maybe somebody find the solution.
Hello guys! Is it safe to flash custom rom shared in this topic? Will I be able to restore original one if any?
Helo sir
I have two radeon vii and I manage to run on c mode like a month, after the hiveos update it went to b mode again … Is there any way to get back.
not sure that you are in B-mode. None of my familiar Radeon VII owners have any problems updating
Pretty sure you already know, but first confirm you are running in 10 bit by checking in Hive Shell with this command:
→ dmesg | grep “drm.*block size”
If not run back through the first stages here:
When I updated the kernel to latest stable I had to run enable 10bit, then all was well:
