I asked this several times on both HiveOS chat (Support and Off-Topic) channels, but no response unfortunately. So I am going to ask here instead. Maybe that will prove more helpful. I did a search on Google as well, but no answer at all.
Running the following command on a live working rig: hive-replace -y --stable
Will that cause issues with it’s current configuration? E.g. WIFI credentials?
Reason I am asking this is, is that I cannot access the mining rig physically. So when I run the “hive-replace” I need to be sure I do retain WIFI access (and ofcourse all other settings). Otherwise I will not be able to mine for several weeks.
Can someone give more details about this and confirm WIFI will be working afterwards?
Thanks in advance.
