Youre card is a sing 8 pin or double?
Or set you’re bios file online can i see what settings it use
This is mine GPU, does it good? Anything Do I need to keep improve it or low volt?
I am using default Bios
8 .im only know about hive os setting…
hii netiya, would u pls inform for a custom bios, tq
Hi, no problem… is there a place where i can paste this file?
can you send this xfx bios file to [email protected] ? Or if you upload into google docs and select public, you can share the link…
