Yes do I need to lower the settings of that 570? I’ll try to modify the 580 thanks
Buenas amigo, soy nuevo en eso y no logro configurar mi RX 580.
tengo esta bios C940 Polaris20 XTX A1 GDDR5 256Mx32 8GB 300e/300m
ya probe con polaris pero no logro que se mantenga estable. te pido una ayuda por favor
it doesnt heat up much so maybe you can keep it like this.
i am trying to download this bios but the link is dead, can you please upload it? will really help me thanks
Buenas trngo una AFOX RX 580. No logro configurarla. Solo llega a 28.3 y con alta temperatura. 1100 3 900/800/1300 1850 def 20. Probe lo que recomendaste aqui y ni siquiera enciende. Podrias ayudarme?
I have my rig setup but it seems like one of my Asus RX 580 cards is having issues with invalid shares. Any advice on this?
All of my cards are BIOS modded also.
I have two MSI, both modded and running at 32.3 mhs @ 80w. Try Core Clock 1200, DPM 1, Core Voltage 850, Memory Clock 2150 and amdmemtweak --REF 20
Have you noted the (1) GPU that is unhappy at that overclock has Hynix memory vs. Samsung and is running 15C+ higher than it’s peers?
Not sure why you have that one running so hot on VDD.
Not sure why you are not setting fixed memory clocks either.
It appears you are running MT variables, but they are not shared.
Yes I saw that the one card was running hotter than the others. I have AMDmemtweak ref 30 running on all the cards.
I had set mem clocks prior but was getting constant crashes after about a min after boot.
At a minimum, I’d back off a bit on the Core and VDD to see if the temps drop and the MH/s increases after a new baseline.
ya te envie un mensaje al privado espero te llegue y quedo atento a la respuesta, muchas gracias
Here’s my stats that give stable results for me. I’m using the 0000 straps from mineros
Straps im using for Samsung Memory
000000000000000022CC1C00EF695D48E03110172ECB95090060060024001520FA8900A0030000000F10303A99262F16
Obviously you will need to flash your bios but for those willing to i hope this helps.
Fans are set to 55% constant
hola, pudiste solucionarlo? tengo 2 afox y no pasan los 8mh
your cards are not bios modded correctly.
First of all , all samsung memory cards need to be bios modded with polaris bios editor 1.7.4.
thats because version 1.7.4 allows you to use the uber mix 3.2 timings which are better.
while modding hit no to ubermix 3.1 and then yes to ubermix 3.2.
then you start with the following settings :
Core clock 1150
Core voltage 850
Memory controller voltage 800
Memory clock 2100
Aggressive undervolting ON
amdmemtweak --Ref 20
Do not use DPM states, they dont work when you set core voltage and clocks. for these cards they are not good.
For the Hynix memory , you just bios mod it. then 1150 core clock , 850 core voltage , 800 memory controller and 2150 memory clock.
wow… your RX 580 4096 MB, can reach 61.28 how can?
It is mining ERG.
