do you mean setting voltages for Memory? I am not sure how to play with it. will do some research. For latest Hive,I noticed they have a newer stable one, will try.
yeah memory controller and memory voltages, the goal is to run them as low as possible thats stable.
Itβs exactly the same for me.
I noticed that the amd version 20.40 (5.11.1001) driver consumes more power and the 20.40 (5.11.0701) driver consumes less power.
so the trigger is AMD driver, not the Hive OS? I will give it a try.
thanks!
I think the power consumption in the new driver is due to vddcr which has gone higher! In the previous version, this number was lower.
In the overclocking settings, I set the soc vddcmax parameter to 850 and now the power consumption is the same as before.
