Nbminer 39.7 3080TI only 59 MH
It’s a with lhr mode 1
83.11-83.7
which model of evga?
Just watched a video @ Red Fox Crypto he built a 3080Ti rig and one card was the EVGA 3080 Ti XC3 ULTRA. He had same issue. Low hash, low power, temps weren’t issue. Read people flashed card with different BIOS(FTW3) and improved hash rate. I’ve never flashed a nvidia card what program do you use?
nvflash for nvdia bios update or change. you can do on hiveos.
Note: first stop miner later try update.
3: overclock.
i checked the video.
  1. core clock use +100 (my idea use lock clock 1600, you can check video 1600)
  2. he not try unlock.
  3. i check more time 90+ C memory temperture.
  4. i have 2 msi suprimx i have 2 diffrent settigns for best mh.
  5. Testing on the card is helpful to be sure of some data. It’s always suspicious unless you’re sure.
If you guys are trying flashing bios and have success please tell us! For now, I have switched my card to Ergo since I just can’t get good hashrate with this MSI 3080ti
i was test bios update not any change.
1111
Tried to flash in HiveOS… for some reason it wont flash and doesn’t give reason. I’ll have to pull this card to Windows test bench and mess with it…what a pain.
if try flash bios change on hiveos, first need stop miner later try flash.
Yes I stopped miner then tried flash. Acts like its flashing but then checked bios and didnt change. Still original bios on card
Are you sure it’s a different bios version? Is it the same version?
I’m try EVGA XC3 ultra 94.02.71.80.C0 and another from 450w evga
And 94.02.71.40.13 by MSI suprim x
All the same
But on evga 450w I’m have 55-77
Evga …C0 I’m have 82-83 and msi same
Oh, or if u abt my card - it’s a msi gaming x
i was say that i try bios change, i get same result.
1111
and i have 2 settings for my suprimx. same model but dont work same oc settings. if i try use gpu4 memory oc:1800+ get lower mh, but i can use gpu5 memory oc:2200 no problem. 2 card same model.
i try gminer 2.71 now, but same result with nbminer.
Hey. Thanks for this man. Works for my 3080 ti suprim
Did you end up getting the low hashrate resolved?
hey, just wondering if you would have any idea
my gpu 5 is an 3080 gaming x trio MSI LHR
it is mining raven with that OC setting with t-rex miner
im not sure if my lhr tune config is correct.
would you have any idea on how to optimize this setting?
thanks a lot
hi,
i havent 3080 lhr model. i found some settings for 3080 lhr model.
For raven
You can try?
core clock: 0
memory: 2000 they suggested (if get high value u can use 2600 try test)
Power limit: 325
my idea found all lhr card best oc settings need some try test.
Cheers
What about 3080 non lhr for msi gaming trio?
I cant reach 95
Barely staying at 92-93
100% thermal issue, change thermal pads.
sunnyii say true, 3080 non lhr many cards high memory tempertures, need change better quality thermal pad. my gigbyte aorus 3080 before replacing thermal pads i get 82-90 mh, i changed the thermal pads you can see result.
High PL can cause LHR lock to trigger, try lower your PL to 285.
