Edit again: XMR-Stack show 19 threads (0-18) but with 10 cards it should be 20 (0-19)
Please post your complete amd config file.
I have also changed the " for the hole file, because when getting it from you it had differnet quite marks (symbols) read it could often be that what was wrong.
Seens like you have only one of the number 1 treads…?
“gpu_threads_conf” :
{“index” : 0, “intensity” : 896, “worksize” : 16, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 1, “intensity” : 896, “worksize” : 16, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 2, “intensity” : 896, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 3, “intensity” : 896, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 4, “intensity” : 896, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 5, “intensity” : 896, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 6, “intensity” : 896, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 7, “intensity” : 896, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 8, “intensity” : 896, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
{“index” : 9, “intensity” : 896, “worksize” : 8, “affine_to_cpu” : false, “strided_index” : 2, “mem_chunk” : 2, “unroll” : 8, “comp_mode” : true },
“platform_index” : 0,
I’ve posted two above
So please add a second index 1 line.
Here is what miner put out now, aslo booting in a loop:
[2018-10-24 13:35:32] : Fast-connecting to pool.minexmr.com:7777 pool …
[2018-10-24 13:35:33] : Pool pool.minexmr.com:7777 connected. Logging in…
[2018-10-24 13:35:35] : Difficulty changed. Now: 35000.
[2018-10-24 13:35:35] : Pool logged in.
[2018-10-24 13:35:51] : All pools are dead. Idling…
[2018-10-24 13:35:51] : SOCKET ERROR - [pool.minexmr.com:7777] CALL error: Timeout while waiting for a reply
[2018-10-24 13:36:21] : Fast-connecting to pool.minexmr.com:7777 pool …
[2018-10-24 13:36:21] : Pool pool.minexmr.com:7777 connected. Logging in…
[2018-10-24 13:36:23] : Pool logged in.
[2018-10-24 13:36:35] : All pools are dead. Idling…
do you use hive 82
Also you can try to use port 14433 at nanopool
Hive OS 0.5-82
Trying indeedminers and minexmr, i will elt you now…
for minexmr you must delete the /%EMAIL% in the Wallet and worker template
The Info says, that for nanopool yoou have to use
%WAL%/%WORKER_NAME%/%EMAIL%
you worte
%WAL%.%WORKER_NAME%/%EMAIL%
Mybe this is the problem
looks good, found nothing wrong
Rig hashing but boots in a loop…this is what i get:
2018-10-24 14:06:29] : Pool logged in.
[2018-10-24 14:06:48] : All pools are dead. Idling…
[2018-10-24 14:06:48] : SOCKET ERROR - [pool.minexmr.com:7777] CALL error: Timeout while waiting for a reply
[2018-10-24 14:07:17] : Fast-connecting to pool.minexmr.com:7777 pool …
[2018-10-24 14:07:17] : Pool pool.minexmr.com:7777 connected. Logging in…
[2018-10-24 14:07:19] : Pool logged in.
[2018-10-24 14:07:44] : All pools are dead. Idling…
[2018-10-24 14:07:44] : SOCKET ERROR - [pool.minexmr.com:7777] CALL error: Timeout while waiting for a reply
I can give you accsess to my rig and you can take a look?
Just need your username
sent you a PM
i think i found the problem …
wow…sounds good
unfortunalty not. First claymore-x started to mine. so i created a new flight sheet.
now all 20 threads are shown an hashing but nanopool has timeout
OK, i have been told that claymore is dead, not working so thats why we have to use xmr-stak.
Do you have a firewall? (on your hiveos, or your home network)?
Only “nat” in my router, and it is no problem mining ETC or ethash algos…so i guess that isnt the problem.
This is as far as i have come:
[2018-10-24 15:52:54] : OpenCL device 9 - Load precompiled code from file /home/user/.openclcache/ff2a42c9db8513763c29a760c9cd5222af4b977988792619e92be22db3c3627e.openclbin
[2018-10-24 15:52:54] : OpenCL device 9 - Load precompiled code from file /home/user/.openclcache/823feed6732556dae1ca52fb69a759fbffd0abecb2e2bd646d4025aae726dd64.openclbin
[2018-10-24 15:52:54] : Device 9 work size 8 / 32.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 0, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 1, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 2, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 3, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 4, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 5, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 6, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 7, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 8, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 9, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 10, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 11, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 12, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 13, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 14, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 15, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 16, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 17, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 18, no affinity.
[2018-10-24 15:52:54] : Starting AMD GPU (OpenCL) thread 19, no affinity.
[2018-10-24 15:52:54] : WARNING: backend CPU disabled.
[2018-10-24 15:52:54] : Fast-connecting to stratum+ssl://xmr-eu1.nanopool.org:14433 pool …
[2018-10-24 15:52:54] : Fast-connecting to stratum+tcp://xmr-eu1.nanopool.org:14444 pool …
[2018-10-24 15:52:54] : Fast-connecting to stratum+tcp://xmr-eu2.nanopool.org:14444 pool …
[2018-10-24 15:52:54] : Pool stratum+ssl://xmr-eu1.nanopool.org:14433 connected. Logging in…
[2018-10-24 15:52:55] : Pool stratum+tcp://xmr-eu1.nanopool.org:14444 connected. Logging in…
[2018-10-24 15:52:55] : SOCKET ERROR - [stratum+ssl://xmr-eu1.nanopool.org:14433] RECEIVE error: socket closed
[2018-10-24 15:52:55] : Pool stratum+tcp://xmr-eu2.nanopool.org:14444 connected. Logging in…
[2018-10-24 15:52:55] : Difficulty changed. Now: 120001.
[2018-10-24 15:52:55] : Pool logged in.
[2018-10-24 15:52:55] : New block detected.
[2018-10-24 15:53:02] : New block detected.
[2018-10-24 15:53:28] : Fast-connecting to stratum+ssl://xmr-eu1.nanopool.org:14433 pool …
[2018-10-24 15:53:28] : Fast-connecting to stratum+tcp://xmr-eu2.nanopool.org:14444 pool …
[2018-10-24 15:53:28] : SOCKET ERROR - [stratum+tcp://xmr-eu1.nanopool.org:14444] CALL error: Timeout while waiting for a reply
[2018-10-24 15:53:28] : Pool stratum+ssl://xmr-eu1.nanopool.org:14433 connected. Logging in…
[2018-10-24 15:53:28] : Pool stratum+tcp://xmr-eu2.nanopool.org:14444 connected. Logging in…
[2018-10-24 15:53:28] : SOCKET ERROR - [stratum+ssl://xmr-eu1.nanopool.org:14433] RECEIVE error: socket closed
[2018-10-24 15:53:28] : Pool switched.
Rig starts to hash but reboots after a short time…
