So first a power disclaimer… I dont own any gigabyte but my understanding is they just display wattage used by the whole card, unlike the rest of vegas which display only the wattage of the GPU die, and not the fans, lights and power loss from the memory controller and VRM.
So if you are using any splitters, or an 8pin to 2 6+2 pin to power this GPU I would not recommend pushing power this high. 8 pin cables are “recommended” 150w max, regardless if they have 16 or 8 pins on the other end.  Probably fine to push higher than “recommended max” but should be plenty safe if you have 2 8pin cables powering this card, as that can safely carry 300w.
Having said that might not be worth the extra wattage per hash but if you really want to see if that card can do 200 and assuming vdd 925 is the minimum you can run 1300 core stable at:
Core: 1440
VDD: 970
Mem: 960
If it mines start dropping vdd by 10 until you find the minimum its stable at.
If that wont mine or crashes, bump VDD up by 10 & restart the miner until it starts mining. If the VDD level gets too high for you drop core to 1420, or next step down would be 1400core 930mem. I’m guessing you end up around 1400 / 960 / 930 for 190-195Mh, or might need a crazy value like vdd 1000+ to mine at 200.
