Tried your settings in HiveOS, they work fantastic! you sir are a genius!
Can you share the oc how it turned out on hiveos?
Using TRM with r-mode?
I found that R mode does not work so dont turn that on otherwise it wont start mining.
What works best are these settings and if you get GPU DEAD error then just bump up the core voltage until it is stable
Hive shows 100w but in reality its more like 140w per GPU and these settings yield about 131mhs
Core Clock: 1280
Core Voltage: 830
Memory clock: 830
SOC frequency: 899
amdmemtweak --CL 20 --RC 37 --RP 12 --WR 12 --CWL 8 --FAW 12 --RAS 26 --REF 22600 --RFC 234 --RTP 5 --RRDL 6 --RRDS 3 --WTRL 9 --WTRS 4 --RCDRD 12 --RCDWR 12
