what type of motherboard do u use?
So the big question isā¦
If there are, like the guys Lolminer said on telegram, an hashrate calculation error, maybe @Tankcortiz should confirm, if on hiveon stats he really can get 48-50 Mh/s for each of his 3060ās.
and confirm if The guys from Lolminer will fix the bug of the calculation, or the fix of the hashrate⦠because if they correct the calculation erro, but the 3060ās will continue to work on 37-38 Mh/s⦠is the same what we already have⦠and for that reason, i prefer keep my rig on windowsā¦
I updated lominer to 1.31 together with Hive OS update. I seem to get 35.7 MH/s which is max 1 MH/s improvement for me but the clocks might be a bit different. Iām using the recommended Nvidia driver 460.39, core clock -300, mem 2200, powerlimit 120 W.
So far canāt see a major improvement mentioned in the title.
What driver are you using for the 3060?
Which Hive OS version are you running?
¿ Cómo lo haces en windows ? yo no consigo tampoco pasar de 20 y el famoso driver no me deja instalarlo.
Made changes like the original poster stated and actually dropped mHs. Went back to original settings of 1430, 2350 and 115PL to get it back to 36mhs. Reboots are frequent (not as frequent as the previous version) and hope they fix this issue.
Hello. I am setting up a 3060 rig like yours with hiveos but it only achieves 38mhs. Could you tell me how you have them configured?
Hiā¦
I guess you are running RTX3060 original version. The same that works on windows with 470.05 developer driver.
Im trying to bypass the new RTX3060 (GA-106-302).
Because this is a new chip the 470.05 driver does not find the card and wont install in Windows.
So im trying the HiveOS/LolMiner method. But it also asks to downgrade to a previous driver 460.39 wich is from Jan/2021. As its an old driver, HiveOS wonāt boot as well.
Does any of your RTX3060 has the GA106-302 chip? I guess its does not come named with LHR but it works equal.
Without the 460.39 driver, im getting only 14MHs
Core -100~-250ćMem 2200-2600ćPL 115 ~125
try core 1500 and leave the rest the same
which miner are you using?
Iām on nbminer, core 1500, mem 2350, fan 75, pl 120, driver 470.74⦠and I get 33.50 mh on my 3060 lhr v2
lolminer v.1.34a
DRIVERS 460.39
my 3060 are the v1 unlock with beta driver for win
