the only thing that makes sense is the local temp raised. you cant create more heat with less power and the same amount of fan/cfm.
It’s the same again, my air conditioners are working, the fans are working, but this is snow and the 3080 rig, this brand card works at 80+ ambient temperature is the same although everything is the same, two different rig conditions are exactly the same but meaninglessly 80+
When it heats up, other cards heat up too.
I’ve never seen this card over 55+, it’s been more than 1 year.
looks like a fan or ac isnt working to me. the temps wouldn’t all be higher with the same or lower power draw. have you looked at the rigs in person?
maybe add a box fan to the rig? or add more exhaust to the room. those cards are cooking. you really should be ~10-15c lower on the core and mem temps than you are in all your screenshots
are you changing the airflow in any way? maybe by opening a door to the room they’re in? can you get a thermometer in that room to see what the ambient temp is before/during the high temps?
Whats the cpu temp when everything is running hot? still 42c or hotter? ← this will answer if the room is getting hotter real quick.
