This post was flagged by the community and is temporarily hidden.
youd need to compare to your pool side hashrate graph. could be an api issue, network issue, pool issue etc
Looks like it could be an issue between your rig and the hive api server. If it continues you can try changing to a different mirror api server in the workers settings
Could you tell me how to do that please?
click on the worker youre having issues with
settings
mirror select
It won’t let me upload another image.
I must add a url where it says: Packages repository server mirror URL???
Could you give me more information? if it is with images, better.
And what do I have to put there? Could you give me that data to copy and paste please?
I am miming in the HeroMiners pool and in the TeamRedMiner miner
click on the worker first (sounds like you skipped this part and were on your farm level)
then settings
then mirror select
I don’t understand…the 24-hour average is not correct?
