Autoswitch for NiceHash|Автосвитчер/автопереключатель для NiceHash
@lexandros
Are you switching the wallet for a dev fee? I noticed my wallet changing to something weird and might be a nicehash wallet
However, if it is you, you need to only switch the nicehash wallet and not all the wallets in /hive-config/wallet.conf
### FLIGHT SHEET "Autoswitch Zhash" ###
# Miner miniz
MINIZ_ALGO="144,5"
MINIZ_TEMPLATE="34TJQUdMYzyV5GNLVFRpRRdFAbgLmVwJ3v.2842067"
MINIZ_URL="zhash.auto.nicehash.com:9200"
MINIZ_PASS="x"
MINIZ_TLS=""
MINIZ_USER_CONFIG='--pers auto
-cd 3 4 5 6 7'
MINIZ_VER=""
# Miner teamredminer
TEAMREDMINER_ALGO="kawpow"
TEAMREDMINER_ALGO2=""
TEAMREDMINER_TEMPLATE="34TJQUdMYzyV5GNLVFRpRRdFAbgLmVwJ3v.2842067"
TEAMREDMINER_TEMPLATE2=""
TEAMREDMINER_WORKER=""
TEAMREDMINER_WORKER2=""
TEAMREDMINER_URL="stratum+tcp://americas.kawpow.mining-dutch.nl:9985
stratum+tcp://kawpow.mining-dutch.nl:9985"
TEAMREDMINER_URL2=""
TEAMREDMINER_PASS="d=188"
TEAMREDMINER_PASS2=""
TEAMREDMINER_USER_CONFIG='--kernel_vm_mode=RR
--prog_hash_report
-d 0'
TEAMREDMINER_USER_CONFIG2=''
TEAMREDMINER_TLS=""
TEAMREDMINER_TLS2=""
TEAMREDMINER_VER=""
TEAMREDMINER_INTENSITY=""
# Miner gminer
GMINER_ALGO="kawpow"
GMINER_TEMPLATE="34TJQUdMYzyV5GNLVFRpRRdFAbgLmVwJ3v.2842067"
GMINER_HOST="americas.kawpow.mining-dutch.nl
kawpow.mining-dutch.nl"
GMINER_PORT="9985
9985"
GMINER_PASS="d=188"
GMINER_TLS=""
GMINER_ALGO2=""
GMINER_TEMPLATE2=""
GMINER_HOST2=""
GMINER_PORT2=""
GMINER_PASS2=""
GMINER_TLS2=""
GMINER_INTENSITY=""
GMINER_USER_CONFIG='--devices 1'
GMINER_VER=""
# Miner lolminer
LOLMINER_ALGO="ZEL"
LOLMINER_ALGO2=""
LOLMINER_TEMPLATE="34TJQUdMYzyV5GNLVFRpRRdFAbgLmVwJ3v.2842067"
LOLMINER_TEMPLATE2=""
LOLMINER_WORKER=""
LOLMINER_WORKER2=""
LOLMINER_SERVER="us-flux.fluxpools.net
eu-flux.fluxpools.net"
LOLMINER_SERVER2=""
LOLMINER_PORT="7001
7001"
LOLMINER_PORT2=""
LOLMINER_PASS="x"
LOLMINER_PASS2=""
LOLMINER_TLS=""
LOLMINER_TLS2=""
LOLMINER_USER_CONFIG='--devices 2'
LOLMINER_VER=""
# Miner bzminer
BZMINER_ALGO="kaspa"
BZMINER_ALGO2=""
BZMINER_TEMPLATE="34TJQUdMYzyV5GNLVFRpRRdFAbgLmVwJ3v.2842067"
BZMINER_TEMPLATE2=""
BZMINER_WORKER=""
BZMINER_WORKER2=""
BZMINER_URL="us.acc-pool.pw:16061
ca.acc-pool.pw:16061
eu1.acc-pool.pw:16061
eu2.acc-pool.pw:16061"
BZMINER_URL2=""
BZMINER_PASS=""
BZMINER_PASS2=""
BZMINER_DISABLE_GPUS="0-2,4-8"
BZMINER_TLS="0"
BZMINER_TLS2=""
BZMINER_LHR=""
BZMINER_LHR2=""
BZMINER_INTENSITY=""
BZMINER_USER_CONFIG='"clear_log_file": false
"log_file_verbosity": 3
"hung_gpu_restart_bzminer": true
"oc_lock_memory_clock": [810]'
BZMINER_VER=""
# Miner srbminer
SRBMINER_ALGO="randomepic"
SRBMINER_TEMPLATE="34TJQUdMYzyV5GNLVFRpRRdFAbgLmVwJ3v.2842067"
SRBMINER_WORKER=""
SRBMINER_URL="epic.ca.hashrate.to:4000
epic.hashrate.to:4000"
SRBMINER_PASS="x"
SRBMINER_TLS=""
SRBMINER_USER_CONFIG='--disable-gpu
--cpu-threads 3
--keepalive true'
SRBMINER_ALGO2=""
SRBMINER_TEMPLATE2=""
SRBMINER_WORKER2=""
SRBMINER_URL2=""
SRBMINER_PASS2=""
SRBMINER_TLS2=""
SRBMINER_USER_CONFIG2=''
SRBMINER_VER=""
META='{"miniz":{"coin":"Nicehash-Zhash"},"teamredminer":{"coin":"RVN"},"gminer":{"coin":"RVN"},"lolminer":{"coin":"FLUX"},"bzminer":{"coi
n":"KAS"},"srbminer":{"coin":"EPIC"}}'
@lexandros
Found out that 34TJQUdMYzyV5GNLVFRpRRdFAbgLmVwJ3v is indeed your wallet
$wald_new$walde_new | openssl enc -base64 -d)
Could you not switch to the fee wallet when mining etchash or ethash. Those algorithms only happen for a few minutes, and switching when doing these is no good for anyone. You just ramp the rig to start mining those and redo the same for the fee. So there is a lot of waste. Would be better if you could try to catch the rig when switching algorithms for you to start mining for the fee, even if earlier than 1800s
Also please don’t change the wallets for gpus not doing nicehash. It is very wasteful to have cards doing nothing for 2 minutes every half hour
Also, am I correct that you switch to the fee mining every 1800 seconds for 120s? That is 6.67% of fees.
Выяснил, что 34TJQUdMYzyV5GNLVFRpRRdFAbgLmVwJ3v действительно ваш кошелек
Пожалуйста, не переключайтесь на комиссионный кошелек при майнинге etchash или ethash. Эти алгоритмы работают всего несколько минут, и никому не нужно переключаться во время их работы. Вы просто запускаете буровую установку, чтобы начать их добычу, и повторяете то же самое за определенную плату. Так что отходов много. Было бы лучше, если бы вы могли попробовать поймать ферму при переключении алгоритмов, чтобы начать майнить на платной основе, даже если до 1800-х годов
Также, пожалуйста, не меняйте кошельки GPU, которые не используют nicehash. Очень расточительно заставлять карты ничего не делать по 2 минуты каждые полчаса.
Кроме того, я прав, что вы переключаетесь на платный майнинг каждые 1800 секунд в течение 120 секунд? Это 6,67% сборов.
извините, гугл переводчик, лол
This is fantastic! The manager made it very simple as I already had flight sheets and overlocking profiles prepared for all my HiveOS rigs. Does anyone know a similar program or a way for it to run on a Windows PC? I’d like to keep using T-rex miner on my desktop but still have NiceHash profit switching between different algorithms. Right now I have .bat files that I manually run after looking up current profitability. Ideally something that simple that just selects between those batch files.
@lexandros thanks, just saw you updated the github to include some of the newer algos
Is there a problem with Autoswitch? I install today and input FARM_ID and TOKEN, but i get this message.
Autoswitch: Wrong answer from HiveOS API. Check FARM_ID and TOKEN variable in autoswitch.conf. Exit
Are you on a free account or paid?
I have two rigs and it is free. Is it the same as a free account?
API access is only available to paid tier accounts, you can enable this in the billing tab → paid features toggle.
You’ll be charged the standard rate based on how many gpus you have explained here: Prices and Packages
