Asus RX 5700 XT Memory temperature
See my reply beow.
hello!
can someone help me to improve all my cards??
Only the first 5700 has a modded bios.
if your memtemp is 94 the your fan should be faster than 74%. try a clean fresh install of hiveos which is with latest amd driver. that should fix some fan control issues and autofan should work better with that. if autofan says target 80 e.g., your fan must be 100% if you go above 80…then you need to start optimizing rig cooling or sourround temps or decrease mem vol!tage / clock to get temps down.
I need one. Can I have one [email protected]
