In the Popular presets section, first enter an existing setting, then enter the settings I gave you. Dpm part will come
Hi FastCrimes,
I have placed a RT6800XT TAICHI , I have not yet put it overclocked
but I was surprised that the initial values (without OC) are
I understand that the RT6800XT without OC consume something like 150 or 160 watts, but not 216 watts, as it was in your case, before the OC,
as it was in your case, before the OC, they consumed that amount of watts?
hello Carlos Javier
I don’t remember, but it was really surprising consumption. After all, the card in my hand is the same, it provides oc consumption.
thank you FastCrimer,
I have achieved the same results as you.
Hola Lmanga,
finalmente lo configure con los parametros de Fastcrimer y si me consume solo 116Watts,
tal vez no dejaste el DPM en 5?
Saludos.
Carlos P.
Cuanto de MH te da?
61.18 mh y 116 watts de consumo. en Team Red Miner,
todavia no lo he pasado a Gminer
Entiendo, yo estoy en Gminer con las mismas configuraciones de FastCrimer y me da 62.1 MH pero a 140W. Incluyendo el DPM
entonces, prueba en TEAM red miner, me avisas si te logra bajar a 116 o 117wats
por que tu tienes RT6800XT asrock taichi, deberias obtener lo mismo.
