Hi, can you share your settings? I have XFX witch Samsung memory getting only barely 29 so far
Core clock 1260
Core state 2
Core voltage 950
Mem clock 2100
Mem state 800
Ref 30
İ get 32 with this settings
amdmemtweak --i (gpu number also remove parentheses) --CL 16 --RAS 30 --RCDRD 12 --RCDWR 5 --RC 44 --RP 10 --RRDS 3 --RRDL 5 --RTP 5 --FAW 20 --CWL 7 --WTRS 4 --WTRL 9 --WR 16 --WRRD 1 --RDWR 19 --REF 17550 --MRD 8 --MOD 15 --PD 8 --CKSRE 10 --CKSRX 10 --RFC 300
For example, this would affect gpu 9:
amdmemtweak --i 9 --CL 16 --RAS 30 --RCDRD 12 --RCDWR 5 --RC 44 --RP 10 --RRDS 3 --RRDL 5 --RTP 5 --FAW 20 --CWL 7 --WTRS 4 --WTRL 9 --WR 16 --WRRD 1 --RDWR 19 --REF 17550 --MRD 8 --MOD 15 --PD 8 --CKSRE 10 --CKSRX 10 --RFC 300
Could you also please comment final timings?
Sure. AMDMemTweak not supported GDDR6 memory
Only HBM, HBM2 and GDDR5
Yea, looks like an open issue in github as well.
It’s useless because the author went to business and will not update his tool anymore for free.
The second point, changing timings on the fly for GDDR6 locked.
I am only getting 4mh on my rx580 4gb card.
Can someone please help me get more out of it please
Put your card to full x16 3.0 PCIe (cca 24MHs) or at least x8 3.0 PCIe (cca 12MHs) and use lolminer.
How do I do that
There is nothing to explain. Dont use riser if you use it and use PCIe 3.0 x16 slot on your MB.
those settings and all undr 50%…??? Not normal 580…not even with micron, not even close… thats Phoenix, right? And fans hardly spinning, some good units u have there!
this guy is being rude, put your car directly to your motherboard, to the long slot, its x16. good luck
Thank you I under stand now
