На микроне какие тайминги?
От samsung
Thank you for confirming!
777000000000000022AA1C00CE615C4190551014B68C450A0060040074081420EA8900AB020000001712262BA42C3714
Попробуй мои, на том-же разгоне будет 35+
rx 580 4 хуникс шитые. какие параметры надо ввести чтобы получить хотя бы 35мг. поскажите?
So do I understand this correctly that it should be used with cards with original BIOS (unedited timings) which it would boost from lets say the original 20MHs for RX580 to the 30+?
What if it is used with custom BIOS cards?
Thanks!
I was able to get 35MHS but uses a lot of power.Anything on lowering power usage?
Короче что я только не делал, 32.5 это максимум
Забил…
Please how your are getting 35m/hs what are your settings
core clock ?
dpm?
voltage?
memory?
ref?
Anyone have a screen shot of settings for RX570’s that is stable on Ethash coins? I keep getting a lot of invalid shares on mine. My cards are Bios modded and are running samsung memory. Right now i’m getting 31.1mhs on ETH but getting about 1 invalid share per hour.
Разгонял до 34.2 мхс,но валятся шары пачьками,+ потребление=греются,так стабильно и вроде как нормально уже неделю
Thanks! I am real close to what you have. I’ll try tweaking it a little more tomorrow.
