it shows that we can’t send it to you , can you send a email to us?
Email: sda@afox-corp
Hello There !
I have this card, and it only works with the STD BIOS with the following settings, i don’t want to break the card, each thing i tried it was unstable, so with this, this is what I got, i don’t mind mining at that rate, but i would love to lower the watts, which i can’t do no matter what I tried, would you please help me out ?
If there is a way to avoid overheating the card, and get a little bit more MH/s plus lower watts (yes, it’s too much to ask maybe) I’m in, otherwise, with lower power watts, I’m happy, thanks in advance for your time !
my emails is: [email protected]
Thanks!!!
BODY { FONT-SIZE: 12pt; FONT-FAMILY: Calibri; COLOR: #000000 } BLOCKQUOTE { MARGIN-BOTTOM: 0px; MARGIN-TOP: 0px; MARGIN-LEFT: 2em } OL { MARGIN-BOTTOM: 0px; MARGIN-TOP: 0px } UL { MARGIN-BOTTOM: 0px; MARGIN-TOP: 0px } P { MARGIN-BOTTOM: 0px; MARGIN-TOP: 0px }
General use has a certain overfrequency capacity, but also to see the motherboard and others of all aspects of scheduling.
And I sent the bios setting for your reference, check pls.
Hola Nineone,
Espero que te encuentres muy bien, tengo 3 afox afrx580-8192d5h7-v2 con memorias Samsung K4G80325FB, podrías indicarme que bios mod aplicarle. Mi mail es [email protected]
Gracias y feliz año nuevo
Hello I just bought few AFOX RX 5700 XT cards and cant find stable mining settings. Anyone with this card to help me?
Hi, please can you send me settings for Radeon RX 5700XT? Cards have memory “Samsung GDDR6 · 113-D199Fighter-006”.
My email is [email protected]
Kind regards
Marek
Hi Marek, thank you for your email, will send you after our technical team reply
thank you for helping me.
One more information about cards. They all have mining edition sticker on backplate.
Kind regards
Marek
I send an email please respond thnak you.
afterall I cant go under 130-140w without degrading a performance. All other my RX 5700XT have much lower power consumpion. Any trick for lowering power consumptions or your cards are just too voracious?
Hello nineone I would like to ask you if it is possible for you to send me some bios for an afox rx 580 8gb that I have Samsung K4G80325FB memories since I can not extract more than 28 mhs in hiveos. my email is [email protected]
From already thank you very much !!!
sent it,pls check
gracias, aguardo el bios .rom
Can you please send the rom to me
AFRX580-8192D5H3-V2(GDDR5)
my memory Samsung K4G80325FB
My mail : [email protected]
some please share the optimal parameters for Afox Rx580 Samsung memory
Good morning Nineone, could you please send me the mod bios and configuration corresponding to my plates, since I cannot have stable mining (capture attached). My email is: [email protected]
AFRX580-8192D5H7-V2(GDDR5)
if i put some Oc…all rig crash and stop mining, i dont know what is happening
please, can you help me? i want 32 - 33 Mh like my others rx580 with hynix mem. =)
