Via hiveos, did everything just with phone, so there should be no problem with remote pc.
Cogito, would you mind sharing your OC settings? You’re getting some pretty nice mhs.
Lorenz, I ended up getting both of my 3060s working on lolminer 1.29. I moved around my risers & I started fiddling with OC settings and eventually one of them did the trick.
Hey joe,
Well done man. You moved back to Core offset instead of Absolute. Why? I put Absolute Clock 1450 Mem 2500 and the wattage is at 107w. Getting almost 38mhs and stable so far. Temp between 45-55° with the fan at 60% (I have PNY single fan).
Good luck!
Hi Lorenz & Thanks!
I actually stumbled on those particular OC settings by going through the popular presets until one of them actually worked.
After reading your post, I was encouraged to try going back to absolute & found some settings that are working really nice. I guess the one 3060 is just happier on lolminer with a lower mem setting. As soon as I go up to 2200 or above, the card wont hash. I even waited 10 minutes like Cogito above suggested. It just sat there showing n/a the whole time
Thank you for the tip, things are looking much better for both of my 3060s now!
just installed the hiveOS new version, i will try to update the drivers the normal way and will see
another question, usually does it takes a long time?
do i need to delete the OC settings that i have for the cards right now, and once its done, i will set them up again?
i will prepare another flash drive with hiveOS in case i get stuck again!
Thanks and i will keep you guys posted!
Cogito, Joe, Lorenz - guys you are awesome!
it works!
i cant believe it - 6 cards and 600 watts! and each card makes 36.8mh!
That is insane! and temp is under 60c
i used Lorenz settings, but i lowered the power to 110 and it works OK
fans are set at 60 and everything is running great!
Thank you very very much!
anybody with invalid shares?
i just got 1
I have lovered my settings because miner restarted every ~40 minutes. Now i use this, and get around 360mh for 10 cards.
I still sometimes reboot, but in 5-7 hours, which i think is ok. I have palit stormx with 1 fan, so cards with 2-3 coolers may have better hasrates.
I think it is fine for this new miner with antilock. I am getting invalid and stale shares from time to time. But it is way below 5% of invalid shares, that hiveon is using as a reason for ban.
This Miner works great my 3 cards run at 106-110w and 37mhs with absolute core clock
Is there any informations about to unlock the full hash rate of RTX 3060 with risers? I have 2 more cards under windows at full Hashrate and want to switch to hiveos.
mine is running stable so far, and after restarting the rig, i got 0 bad shares!
6 cards and under 600W - i barely hear the rig working
i like running efficient instead of to the max! continuing to test it, but since yesterday, knock on wood, no worries!
i got 5 cards with 3 fans and 1 with 2, but all are giving me same hashrate
Try to install some 90 or 120 mm case fans, to lower the temp and make it easy for the fans that are on the cards
Farm is open, have additional fans and stand under the roof at attic. Its up to 30 Celsius outside right now, and roof is getting pretty hot under the sun
yeah, attic will always be hot…
i got 2 rigs and right now testing in my living room - the whole floor right now is super hot
after making sure they run stable - will move them to basement - summer is coming and temp will go high!
Has just bought another 3060 and put on an 11 years old motherboard with LGA775. The exploit still works. These cards are the best price for it’s hashrate.
Hello adam!
Wow man! How can you do that? So, you change your motherboard, bought another 3060 and you still getting almost 50mhs? Are you still doing the fan trick?
I’m seeing you change the driver to 460.39 and upgraded HiveOS. Which miner are you using? Using risers? Can you make a video?
Please tell us how you are getting there!
Yes, still doing the fan trick. I use another copy of HiveOS on a flashdisk for this mobo and upgraded driver to 460.39 to test lolMiner’s 75% hashrate. It is works. But I still prefer to exploit the glitch.
I’ve made a short video for you, sorry for bad english
https://youtu.be/IL-Rli5N1Oo
One card achieve 50,17 MH/s with mem clock 2800 MHz and power limit 115 watt. Awesome card!
I think I should get another mining mobo and another 3060s.
Hey Adam,
Thank you very much for the video! Your English is very good, don’t worry about that. The only thing is that you don’t show HOW you are doing the fan trick. Is it too much to ask?
I tried many times and no luck for me. Maybe I’m missing something. If you can, please make a video when you start the rig and then with the fan trick.
Thank you very much!
