interesting, i tried like 2 times, and i am dualminig on another rig, simiral configuration - i got mixed nvidia and 1 3060. so i set it up on lolminer and i am getting 38mh constant and the rest of the cards on Trex - much better temps and stability in general.
the fan error - do you do something to recreate it or just set the flighsheet and restart the rig and it does it on its own? some OC setting specific maybe?
When i tried the other day, eventually Trex card started mining with 28mh but the other on miniZ no…
i will try now!
crossing fingers
Hey, any chance you could help me to set up my only 3060 LHR V2 to mine on miniz while the rest stays on T-rex. Im not mining through risers, I mine on BTC-S37 so it might not even be possible. I tried with miniz before for the whole rig but the 1660s wouldnt go above 28 mh/s and the wattage went up crazy for all gpu’s with miniz, so I switched back to t-rex.
This is my config so far.
Thank you.
Best regards, D.
Wallet and worker template: %WAL%.%WORKER_NAME%
Pass: x
Pool server:port: %URL%
hola nose donde preguntar tengo 3 placas 3080 las 3 con ricen, arme un rig el problema es que 2 las tengo en el pci x16 y me las toma pero la tecera la que conecto al puerto pci x1 no me lo toma probe con windows actualice drivers y aparte use hiveos y me sigue tomando 2 no 3 aparte tengo dos puertos pcix1 y en ninguno anda la placa la probe y anda
i did that, same thing…cards are online but they wont mine!
deadend street
Fijate de tener en la bios
- Habilitado el 4g
- Los puertdos configurados en generacion 1
-Deshabilita todo lo que no uses(audio, puertos sata,etc)
Hey guys
Can anybody help me please
I am struggling with that 3060 msi Ventura 2x OC 12g I just bought !!!
I was sure it wasn’t a lhr version
Any possibility I am just doing something wrong ???
Or driver problem ??
First line on the picture
Buenas noches, consulta las tenes en algún modelo de mother en especial, porque lei que tienen que tener un puerto PCI de ciertas caracteristicas. Pensaba usar un Z490-P para armar un rig de 6 3060.
Saludos.
podes armar un rig con esa z490p solo que te va a dar 40/41mh con miniz
Muchas gracias.
You are using Nvidia driver 465.31 you must use version 460.39.
Run the command “nvidia-driver-update 460.39” (without quotes) at the top of the page in (>_)
And the most easy is to use Lolminer with extra parameter: --devices 1 for this card and for the rest T-rex with extra parameter: “devices”: “0,2,3”
Buenas pebi y a toda la comunidad
los 125 mh son de pool o de los que estás minando no logro conseguir más de 86 mh tengo zotac 3060 oc lhr me podrías echar una mano estoy súper mal por qué no paro de buscar y no consigo sacarle más de 34 mh eth muchas gracias por todo de antemano un cordial saludo mucha fuerza
Manuel como estas? Sabes todas las 3060 son “lhr”, tenes idea si es version 1 o 2?
Versión 2 me da un fallo pero el porcentaje no se pone en 0 desaparece junto a la temperatura y ya se cae el monitor pc minero sigo monitoreo desde web y pone 27 mh t-rex no sé cómo hacerlo la memoria la subo hasta 3200 lo demás como tú aver si tengo suerte y doy con el truco gracias por todo de corazón
Descargo el driver Nvidia 460.39 y me da fallo pc no se enciende y el hiveos no lo encuentra no se que hacer me podéis echar una mano porfavor gracias de antemano
Claro es que con la version 2 solo podes saltar la limitacion usando nbminer y solo la desbloqueas a un 70%. Sino te conviene minar otra moneda
Ok muchísimas gracias estoy intentando poner otro driver y intentar llegar a 125 mh con el 470.40.31 o 460.91.03 aver si hay suerte muchas gracias por los consejos soy muy nuevo en esto solo llevó una semana compre una zotac rtx 3060 12 GB OC pero sin conocimiento de que hay LHR y menos dos versiones
pero bueno espero todo esto se solucione y entre todos podamos concluir el desastre que quiere hacer con las personas que necesitamos una pequeña extra un saludo y buen día muchas gracias de nuevo compañero
De momento en tiempos muertos nbminer 34 mh:muscle:
