You are welcome
Hi
my first problem is i cant find best frequency for give max hashrate !!!
my cards is ASUS TUF 1660super with micron memory
i have 2 RIG with same cpu same MB( h110asrock) and ram (4GB) EVEN graphics is same
but when im try to enter my RIG1 setting to RIG2 … miner fall to restart loop ( miner program loop)
and some times one card Fall and hiveos show 0%
thank you
You think the micron memory for 1660ti would work with these settings?
Sorry my settings are for Ethash
I switched to miniz for my rig with 3060v1 are getting 38.6mh
Anyone care to share their settings?
What brand of mem?
For Eth?
Dont know why ppl try T-rex, Gminer etc when they are all the same, and with this settings Rog Strix V2 3060 has been stable without spikes for me past 2 months with mini z. It will fluctuate first 5min, but if you make sure you use same settings, it will stop fluctuating and stabilize like you see in the pic.
Yeah I’m mining Eth…
EVGA
Core 1440
Memory 1640
Samsung memory
PL 0 - Sits around 100-105 watts
This gives me 38.6mh for both my cards.
Mine is V1
I’ve tried NBminer about 1 month ago couldn’t get higher than 25-27
I was using lolminer but before miniz again about 1 month ago but was only getting about 35mh. And was a bit unstable, miniz is a bit more stable to my liking right now.
My other 3 3060v1 run in windows and give me 48mh
Anything in hive do this yet?
Your values look very good. Does it affect the lifespan of the video card?
As long as the temperature is stable and the card does not crash. so no Problème or danger for life carte.
Can you share your pl values?
What miner you using?
Ive had a similar issue with latest miniz RC2 lowering my 3070 non lhr card by 10MH and reverting back to lolminer bring it back to normal…
Hey,
I was wondering what’s the nvidia driver version you use for these cards if you may tell me please?
Are the cards stable for a long period of time?
Thanks,
For that rig I’m using 460.39 and as of yesterday switched to Trex which seems to run fine so far. Though the miner has restarted a few times.
Lol miner for me had wild power swings which was caused by the LHR lock I think.
Miniz recently was giving me rejected shares so I’m trying Trex now…
N460.84
